Hi folks---I have a 63 Vibroverb with a howling/distorting reverb issue. When the Reverb is "on", there are certain notes that produce a distorted buzz that sustains. Also, the amp will produce a feedback type hum when the reverb is engaged. not sure where to start-- the amp has none of these issues when the reverb is not on.
The amp is stock as far as I know, except R58 was changed from a 1k to a 3.9k in order to correct the bias issue, and the speakers were replaced with Jensen C10q's. also, the reverb driver and recovery tubes are both new. (V4, V5)
Any thoughts? I am not an amp tech by trade, but feel comfortable using a multimeter and a soldering iron, and understand the safety issues when working on tube amps.
any help troubleshooting this would be great!! thanks so much--
d
d
