Run a jumper wire from the gnd point at pins 1 and 8 over to pin 6 where the other cap that doesn't show a gnd connection. That should get rid of the hum. When you removed the old caps I bet you snipped a gnd wire and didn't realise it.
SUNN Model T 2nd Gen Power up ?
Nope. There's no connection to pin 6 on most common pin compatible octal tubes used in guitar amps. Thats why some mfgrs use it as a tie point. Jumper the other cap to gnd and I'll be you'll be in business.The farmer takes a wife, the barber takes a pole....
Originally posted by Gtr_tech View PostNope. There's no connection to pin 6 on most common pin compatible octal tubes used in guitar amps. Thats why some mfgrs use it as a tie point. Jumper the other cap to gnd and I'll be you'll be in business.
ok...got the cap straight , powered it up , definitely better , but still some hum, and when I turn the volumes up there's a horrible buzz/hum . I noticed one of the preamp tubes is brighter than the other two also. Got the preamp tube straight....still way too much noise.Last edited by gtrplayr1976; 11-30-2010, 01:12 AM.
Whats the ripple (AC voltage reading) on pin 5 of the output tubes now? If there's still more than a few MV then the diode is leaky. Hum from another part of the preamp can be sorted out *only* after the bias supply is clean.The farmer takes a wife, the barber takes a pole....
Originally posted by Jazz P Bass View Post1N4004 diode.
About as common a diode as they get.
Got a Radio Shack nearby?
99 cents each.
