Hi guys,
My first post here...
Im looking at a Trace Elliot for a friend. AH300, schematic canbe found on this thread
http://music-electronics-forum.com/t19560/
The issues is, is that there is about 55v at the output terminal, reading with an osciloscope, it appears to be AC. This voltage only appears when the relay (shown in the power amp schematic) turns on. Could someone explain the reason for this relay please?
The negative PS cap (4700uF, 100V, -70v) has some damage to it, but it still works , however, it take a very long time to discharge...
....so first things first, ill replace that. But other than that, I need help determining the cause for this dangerously high voltage at the output.
Thanks for your help
Charlie
Charlie
