Okay, here's the problem described in two simple diagrams:
Here's what's wrong right now:
Here's what I'm aiming for:
And here's the schematic in question:
As you can see, the 500KA reverb pot isn't functioning the way I'd like, and since I cannot remove the pot easily, I'd like some help and suggestions on how I can add or change resistors to improve the mix. I have easy access to the 100K balance resistor and to the legs of the pot (to add resistors in parallel or series) but cannot remove the pot itself from the chassis.
The goal is to bring the entire wet signal up dramatically so that it reaches Fender surf levels between 8 and 10.
Correct me if I'm wrong--here's what I'm currently thinking:
1) Increase the 100K balance resistor to force more dry signal into the wet circuit
OR
2) Add a 100K resistor to the top leg of the 500KA reverb pot so that it acts like the pot cuts off at 8 when it's turned to 10. This of course doesn't bring the wet signal up in the mix, so I'd rather not do this except as a last resort.
3) Some other idea...
Any help is much appreciated!
OR
