When you've exhausted grounding as a source for the moment, start looking at capacitive pickup or magnetic pickup.
Try the same turn-off-the-power trick. Does the remaining hum vanish or get smaller? If yes, the AC power in the box is doing it somehow.
Get a 6V lantern battery and power the heaters from it for a short test, opening up the heater winding out of the transformer (be careful and don't short the heater winding doing this). Does the hum go down a lot? If yes, you have heater issues. If no, the heaters are not contributing.
Short the grid of the input tube to ground right at the tube socket. Hum vanish? If yes, it's coming in on the input wires. No, it's not from the input tube section.
Divide and conquer.
Divide and conquer.
