fender stage 100 combo no volume
  • fender stage 100 combo no volume
    so, i decided to stop using my stage 100 as a table.
    i stopped using it around 6 years ago after i acquired better equipment, but it was also giving me a small input problem.
    about a year ago, i blew a speaker in sunn cab i was using, so for a quick fix, i took the 12 inch celestion out of the stage 100.
    now, after not having equipment at my apartment, i thought it'd be a good idea to put in a 15 inch eminence speaker and fix the input problem.
    i hear nothing out of the speaker except for a very, VERY, low fuzz that changes pitch when i turn the volume knob.
    any ideas? could it be the input, or did i not put the speak in correctly?
    i'm not really a tech-savvy person, but i know basics.
    If the amp was giving you "input problems" (not sure what that means, cutting out like a bad connection?) that may still need attention. Other than that I would say that any amp that sits for a time can develop oxide on the switch, pot and jack contact points. Try cleaning the jacks, switches and pots. All of them. Effects loop, input, output and any others. Put a little contact cleaner on a 1/4" phone plug and plug it in and out of each jack several times. Spray a small amount into pots and switches and operate them vigorously. Ideally you would open the amp up and actually use a mild abraisive on the jack contact points themselves. With "switching" jacks that may be the only way since the 1/4" plug may never actually touch the switch contacts. If they're sealed jacks then it's hard to tell if the jacks are the cause without replacing them. It's a good place to start though and won't cost much.
      Plug your instrument into the FX Return jack.
      If you have volume now, the problem is before that jack.
      If you run a cord from FX Send to FX Return, that will bypass the normally closed contacts on the jacks.
      If this helps, then you have a cruddy jack.
      If it does not help, then the problem is in the preamp.
      Most likely a bad solder joint on the input jack.
      Then again, if the amp fell over at any time, face first with the cable plugged in the jack, well......
