Hi all,
this is my second amp repair project – I'm zeroing in on a diagnosis here & wanted some feedback.
Amp is a Yamaha G100-212 III. My bandmate loves to run the thing at full blast, which he was doing when it died during band practice. The sound sort of fuzzed away then disappeared. The power light still comes on and I can hear the relay click. Preamp section works fine - tested via the amplifier's headphone jack - but there is nothing getting to the speakers, not even the usual pop when the relay comes on. Speakers check out, so I'm assuming trouble in the power amp section.
Looking at the board traces by the speaker jacks, I can see a spot that looks burnt - components there are a 7815 voltage regulator and a 24vdc relay. Input voltage on the regulator is ~15VDC, but the output is like 24V which is out of spec. I can't seem to find a pinout for the relay and I have no schematic so it's hard to say what should be going thru it.
My questions to you: is the problem likely just the voltage regulator, or is the relay potentially fried too? Should I just go ahead and replace the 7815 and see what happens? Should I tell my bandmate to turn the **** down?
Cheers,
Jesse
Cheers,
Jesse
