I just finished going through 2 of these bass amps, so I want to document what I did with them (the internet is my notebook )
Here's my repair procedure:
Acoustic 370 Repair Procedure
1) Replace all output transistors Q306-Q309 and Q311-Q314
Match transistors for Q307-Q309 and Q312-Q314
RCA 2N3055 Hometaxial - 2N3055HOM - Transistor, NPN silicon. P/N: 2N3055.
RCA 2n3773 - 2N3773 HOUSE - Transistor, NPN. House No RCA1B01.
MJ15015- MJ15015G ON Semiconductor Bipolar Power
2) Replace driver transistors Q305 & Q310
RCA 40409 & RCA 404010 (integrated heatsinks) or 2N5320 & 2N5322 (add heatsinks)
3) Check all resistors & caps around the output & bias circuits.
With Q305-Q314 removed, it's easy to accurately check the values of most of the related output section components without having to lift them from the PCB.
4) Replace bias transistors Q303 & Q304
2N2222 or 2N2484 or MPSA09 for Q304
2N3053 or RCA 40408 for Q303
5) Replace diodes CR306-CR310
1N914 for CR306 & CR307
1N4731A for CR308
1N4933 for CR309
2 1N914 in series for CR310 or 1N3886 or MR2361
6) Replace R339 & R340
100 ohm 1 Watt Flame Proof - mount 1/4" up off the PCB (I've seen these burn)
7) Replace R319
680 ohm 1 Watt Flame Proof - mount 1/4" up off the PCB (I've seen this one burn, too)
8) Replace rectifier bridge (both amps I had with blown output transistors also had blown rectifier bridges)
BR401 or equivalent (like GBPC4002)
9) Replace all electrolytic caps in preamp & power amp
13 1uF 35V
3 2.2uF 35V
1 6.8uf 35V
3 10uF 50V
3 100uF 50V
10) Replace power supply caps
1 1000uF 100V Screw Terminal
1 3900uF 100V Screw Terminal
1 8200uF 100V Screw Terminal
New Caps are smaller diameter than the old ones, but the biggest clamp can be removed & replaced with a new 1 3/8" clamp (Mallory VR3A). Shift the 8200uF cap over to the clamp where the 3900uF cap was, put the 3900uF cap in the new 1 3/8" clamp.
11) Replace C401 & C401 EMI/noise suppression caps with current safety compliant X2/Y2 class caps.
C401 can be either X2 Class or Y2 Class. C402 MUST be a Y2 Class.
PME271Y547MR30
C401 can be mounted directly on the power switch, if preferred. If this cap is not present, you will get a loud pop when powering the amp off.
12) Check L301 & R328 for open
13) Check R131 100K (notes say a drift here will cause motorboating - change to metal film?)
14) Check R314 270K (I had one that read 410K instead of 270K)
Optional:
15) Replace C311 & C312
.002uF 1KV
16) Replace R104 10M carbon comp resistor with 10M ohm metal film & R125 8.2M resistor with 8.2M metal film
17) Replace R330 with 6.8M ohm metal film
Additional parts to have on hand:
1.0 ohm 1/2 Watt(3 total - R321, R324, R326)
2N4248 or 2N3906 (3 total - Q102, Q301, Q302)
2N2484 or 2N2222 (9 total)
2N4360 or 2N5462 P-Channel FET (1 - Q316)
1N914 (5 more total)
7A Slo-Blo Fuses
7A or 8A Slo-Blo Fuses w/pigtails for internal fuse
I marked the components on the PCBs as I worked on them, so here are pics of the preamp & power amp boards, starting with the preamp (I have both versions of the PCBs in the 2 amps I have. C129 in the preamp is on the trace side of the PCB in the earlier rev):
1N4731A for CR308
1N4933 for CR309
7) Replace R319
13 1uF 35V
3 2.2uF 35V
1 6.8uf 35V
3 10uF 50V
3 100uF 50V
PME271Y547MR30
Optional:
.002uF 1KV
7A Slo-Blo Fuses
