Hi,
I built a Hiwatt DR103 clone that worked for a few hours just fine but at a last session after a few minutes of power off and then turning it back on it audibly changed after the first few notes to a much lesser power level.
If I play notes very lightly it sound as supposed but as soon a harder note is played it changes to a fuzzy and compressed sound. It could also be noticed that the valves start overdissipating while playing even at very low biasing. I had modified the original bias circuit with a voltage doubler so I can adjust within a wide range. The voltages are in the allowable range.
That's what I already tried/ruled out:
-) visibly nothing is burnt
-) change tubes -> same result
-) use an external DC-source for bias -> same result
Anyone which had to track down a similar problem? Any clues to investigate further?
Thanks, David
Thanks, David
