Hello all,
I know this is a subject run into the ground, (ha) but I haven't found an explanation as it pertains to my situation. I've built a Marshamps Princeton Reverb clone, and there is a manageable but definite 60Hz hum. (also the hum is significantly increased when the reverb is turned above 3 or 4, even with no guitar plugged in, but that's a discussion for later) I wired it up with a ground bus, and it sounds great except for that hum.
My question is: I'm using a cap can, and all of the filter caps are tied to one ground that comes out of the can; therefore, I can't separate out the grounds of the filter caps to different parts of the circuit as in the Hoffman ground buss method. Does anyone think that could be contributing to this? I've looked at star grounding, but it seems like it would be a lot of work to rip my bus out and rewire everything.
I've been playing with it for a while, and the way I have it grounded now is in the picture below. This gives me the least amount of hum for my bus configuration.
Any suggestions would be much appreciated. I usually try to get what I need from what is already posted, but I haven't found anything addressing this particular issue.
Also, I know ground hum can be attributed to any number of issues... I'm just wondering about this particular issue with the caps grounded together.
Thanks!
Joe
Thanks!
Joe
