Hello,
Here are the schematics: http://web.archive.org/web/200711012..._dominator.pdf
Here is a picture of the same model just out of interest: Alan Vale's Watkins Westminster 14 Amp
I am stumped by 2 issues in a 1962/63, 2 x EL84, Watkins westminster combo. Which is virtually the same as the 18w Marshalls and the Watkins Dominator.
The amp appears to have had zero work done in its life and appears to have had a yellow print Mullard EZ80 rec tube installed, poss from new?, instead of the higher speced EZ81 shown on the schematic. After one new EL84, one 12ax7, cap, res, deOxit work it sounds really great but there are issues.
First off, the power filter multicap was spitting fluid so was replaced with new as were most of the 0.01uf 400v HUNTS caps and a couple of .005 uf as many tested over, and occasionally under, 20% of the rated specs, including a couple of resistors. It is now lovely and quiet on both the trem and norm channel. However the trem bias oscillation wont be stopped with the depth pot fully counterclock or even grounded.
Secondly the Normal channel tone seems to do nothing until it is turned fully clockwise and then from 8-10 gets more muted/bassy.
I have tested the 500klog, 1k and 2M pots (vol, tone, depth and speed) as good and have checked the wiring many times.
I wish all of this forums contributors and readers the best in all their endeavours.
I have a replacement EZ81 on the way and wonder if the voltage ratings may be at the heart of this issue.
Any wisdom will be appreciated,
Have a good xmas everyone, Metro
