I recently acquired a non-functioning Blackstar HT-100 head with no output tubes. Without the output tubes installed, all the switching and major power supply sub-systems seem to be just fine and the preamp produces a nice clean drive signal for the output tubes.
However, when the amp is turned on with new output tubes installed they go into "red-plate mode" almost instantly (several sets tried, just to confirm). The Standby switch doesn't disconnect B+, it forces the tube in and out of cutoff so you don't hear output but it is a fully functioning heat generator from the get-go.
I assumed the bias voltage at pin 5 of the EL34s should be in the ballpark of -50Vdc but I find +25vdc there! Problem identified!
I am sure I can fix this after an investment of multiple hours by going blindly through the circuitry looking for the problem but they use a different sort of bias control arrangement that appears to be a bias set/bias balance affair with 2 controls that do not appear to be left-right bias controls as they are interactive in a fashion that suggests the set/bias arrangement (based on my experience with the HT-40 variant that appeared to use a similar arrangement).
Since I do not know what the topology arrangement is without reverse-engineering it, I'd like to see if anyone has a schematic for this beast (or any one of its 40 or 60 watt relatives in the HT Venue series) that would give me the clues to this bias circuit arrangement.
Thanks for any help that may be forthcoming!
Steve
Steve
