I'm about to fix some things in a Fender amp, like bias. Up till now I've only seen bigger power stages, 4*6L6. This amp has 2 6L6 with the same cathode bias as I've seen before. The thing the got me wondering is the plate voltage. It's lower in this amp approximately 430 V. When I'm googleing around I see plate voltages down to 415V in the same power stage set up. I seem to remember seeing plates close to 500V.
Why did they, Fender, alter the B+ so much in different amp even if the board was the same? Does it affect the tone in the preamp a lot..? What's the functional limits, max min plate, for this power tube set up?
Edit, What wattage are you aiming at when you adjust bias in Fender amps. I often go quite low. I read that Fender amps are at their best with low bias, well somewhere on the net someone said so, I've stuck to that since.
