Hey guys, I have a Fender Twin Amp reissue that gets a serious hiss when switched from the 25w setting to the 100w setting. At 25w it plays and sounds just fine. At 100w it also plays fine but you are playing over a serious hiss with the occasional crackle and very light pop. I pulled the preamp tubes one by one and the problem completely goes away when the phase inverter tube is pulled. It is V4 on this amp. Any other tube removed did not cure the issue.
Here is the schematic
http://support.fender.com/schematics..._schematic.pdf
At the 100W setting I am reading ~275VDC at the plates of V4 and about ~90VDC at the cathode. The schematic says that there should be 36VDC at the cathodes of V4. What could cause this? As you can see from the schematic it is the "Y" supply that is feeding the plates of V4 and my reading of the "Y" supply line matches the schematic pretty close at ~320VDC (schematic reads 315VDC).
