Hi all,
A guy brought over this amp and it had a noisy preamp tube in V1 so I swapped it out and played it for a few minutes and all was okay. I ordered 5 tubes to replace the originals per his request. Plugged them in tonight and turned on the amp and there was no sound. About 30-45 seconds later a capacitor popped and we had smoke. I had previously pulled the chassis to look it over. I did notice the 470 ohm 10W resistor (R86) had heated up the power connector next to it where it was starting to melt.
What I found was the 470 ohm (R86) had blown apart, C48 100uf 50V popped and the protection diodes appear to be bad. I'm just wondering what the heck happened. When I put the preamp tubes in I did reach under the chassis and put them in by feel. I didn't have any bent pins after I checked and all tubes test good including the power tubes. I check them on a Hickok after the failure. I'm almost positive I had the speaker plug inserted good but maybe it wasn't all the way in. I may have got in a rush and made a stupid mistake.
Just trying to figure out what happened. Anyone run into anything similar before? Maybe it was going to fail anyway. Any advice is appreciated.
Thanks,
Steve
Thanks,
Steve
