I have a1965 Deluxe reverb and it it is not sounding good at all when pushed 5 plus on the volume on either channel.
When I bias it all is good idle with matched 6v6 tubes. If a OT is going bad they usually don't bias properly, right? Idle, the bias is fine (30/29ish) but when played at 6 with bias meter in place one tube bias swings much higher than the other - like 80 vs 50. Is that an indicator of a OT going bad??
All the usual suspect, out of spec components have been replaced, including filter caps, some coupling caps, some mixing caps, some bypass caps and some +10% resistors. Voltages all are within 5% of spec, tubes tested and subbed etc. OT is NOT running hot and no fuse issues. It just sounds raspy and the harmonic overtones after the (mostly mid) notes blossom just ain't "Deluxe Reverby".
I think I am trying to keep this thing original at the expense of having it not sound good and that is kind of dumb!! Thanks if you can help!
