Hi there. I 'm new to this forum and i have a problem that many people seem to have.
I've searched everything on the net and could not find the right thing to do.
I Have a Marshall TSL60 Head made in 2006, the amp plays really well and i had no problems with it at all. The only problem is that now i bought a delay pedal to use in the loop and it just seems useless.
There is as i found out a signal bleed from my main channels to the fx loop and from my FX loop to the output. When i use the delay with the clean channel and i turn the loop off with the footswitch and turn the fx mix knob all the way back the is a slight echo heard through the amp , the problem gets bigger with the crunch and unbearable in the Lead channel. The only fix for the echo to stop is to turn off the delay pedal. The other bigger problem is that when i tried to use the delay and a boost pedal after that in the loop to create a solo sound in the lead channel it immediately starts to feedback like crazy (because i supect of the signal bleed crating a feedback loop) making it unusable.
Some guy suggested the whole fx loop circuit to be moved to a less "noisy" enviroment in the amp chassis , another one suggested the loop to be made Serial instead of parallel but i haven't found out how to do either of these mods.
Does anyone know of a solution to this problem? Is this a crosstalk problem because the cables run together? What should i do? please help
