Here's an odd one which I have not encountered previously. I'm working on an amp based off an old Supro, paraphase PI, cathode bias 6L6, @ 400V B+. The original amp I have did not have a bypass cap on the shared 6L6 cathode resistor. I connected one (30uF) to the cathodes, but just temporarily I did not connect the ground as I wanted to try playing it both ways using an clip lead to see how the difference sounded. I like it w/o the cap better, not very much of a difference but here are a couple of issues:
(1) I have always read that adding the cap adds more gain. Every cathode bias amp I've ever had or built used a cap, but when I clip in the cap, what I notice is almost a very slight "damping" of the sound. It might be making a hair more gain (it's really not that noticeable in this particular amp) but it seems to lose something, it seems to get a bit "flatter" if that makes sense. Is this normal?
(2) It sounds great w/o the cap as I mention UNTIL I get the volume up to about 9, at which point when I totally crank it, all of a sudden there is this weird squealing whistle riding over the notes. The sound it still there, still sounds the same, but there's this damn screechy whistle on top of everything. I feel that is an oscillation of some sort? But why - what does the cathode bypass cap have to do with this? Again, this is *without* the cap.
??? Any thoughts appreciated.
