I've read up on these but still can't solve the issue.
Preamp sounds OK but is humming. Going into effects return, guitar turns in a robot sound with a Univibe effect. Volts all look good. Speaker, which is main ground, was loose. I read some have rebuilt the PS board which I may have to do. Cap's lead were loose/cracked here prior. Swapped in good tubes everywhere. Main issue seems in the output section.
OT primary= 142Ω. OT sec= .9Ω
Any ideas?peavey-vtm-60,-120.pdf
I'm surprised by the amazing design Peavey did on this.
EDIT: The output heaters are now hard wired too. New PS caps ordered.
