This amp will only engage the tremolo effect once the speed control is set to 10 and wait one second. From there, you can back the speed control down to 7 and still have the tremolo effect. As you turn the speed control from 7 to zero, you loose the trem effect and the neon bulb just stays lit on the roach.
I have -68VDC going into the speed circuit & 475VDC "Z" voltage. I've replaced the V6 trem tube, the LDR roach, all three RC circuit caps & resistors, and both cathode bypass caps. The footswitch jack is shorting to ground and both speed & intensity controls are 5Meg verified.
Anyone run across this before or have any ideas?
Thanks in advance,
Steve
Thanks in advance,
Steve
