figuring out rectified DC volts; reversing a transformer
    What is sinking in to me is this.
    You are just doing things.
    There is no basis for why other than "this page showed me"
    Therin lies a recipe for disaster.
    I think you should back up from this repair & start studying why things are in a circuit.
    This repair will always be in the back of your mind, which will set off little "ahah" light bulbs when something makes sense that you can apply.
    Live to Learn
    Learn to Live
      Live to Learn
      Learn to Live
      i don't really think that's fair. i've had a logical reason for doing everything i've done. but yeah, sometimes that logic is flawed because i'm not a trained amp tech.
      again, i get the point. i need some more basic mentoring to be safe about what I'm doing. understood.
        I applaud the advice to take it slow and learn things. I have a scar on my finger from an electrical arc that went straight to the bone back when I first started playing with amps. A 700+ volt supply was to blame. Thankfully I was probing with one hand behind my back and I didn't die.
        I would look for a transformer with similar mounting dimensions and just build a more normal power supply. The doubler seems goofy to me.
        jamie
          Your comments: "I'll preface this by saying I'm not trying to sound like an ungrateful jerk, but I will admit to being a bit frustrated by people constantly saying I should just take this in for "proper repair." This is all a new hobby for me, but I'm not an idiot. I know very well how to treat high voltages, and I don't do so without undo caution."
          The main thing I was pointing out was that 99.99% of techs do not wear any gloves, especially two pairs of gloves!
          That comment reveals the lack of real basic training and it would be a very inexperienced tech who would do that.
          There is no security in gloves like that and to be honest, they'll just get in the way.
          The right approach is to take some time to understand how to simply handle the amp in a safe way, with and with out power applied, which means understanding how the 120v or 220vac line in the amp is the REAL killer in your amp (not the high voltage secondaries) but of course, learn the basic "how to drain off the high voltage filter caps" issues, etc....
          The other point would be knowing how to safely test the amp with 120vac or 220vac applied... no gloves allowed.... and get useful information while while fully powered up. 220vac is nasty!!
          Before jumping in, thinking rubber gloves will keep you safe, ... you just need to ask questions and listen to solid answers because, there are LOTS of techs here with no hidden agendas or axes to grind... feel free to ask first and have fun with the hobby while being safe, not sorry.
          Bruce
          Mission Amps
          Denver, CO. 80022
          www.missionamps.com
          303-955-2412
            agreed. I know folks on here are giving me solid advice and just don't want us newbies killing ourselves. I'll admit to being a bit defensive. But definitely taking the advice to heart before I work much more with the high voltage stuff.
              Excellent....
              Here's is an excerpt from a friend of ours here, Randall Aiken. His website is LOADED with high quality tech info.
              TechInfo_2
              Safety Tips for Working On Tube Amplifiers
              Safety first!
              Okay, you want to work on your own amps, but you've heard various horror stories about things inside amps that can store a charge and kill you. Well, it's true! However, a little common sense can go a long way when working around dangerous voltages.
              Rules to live by:
              • Never work on an amp while talking to someone, either in person, or on the telephone. I have gotten more severe shocks by accidentally touching things while someone was standing there watching me, asking questions. Never work while distracted!
              • When probing a live amp, keep one hand in your pocket - it's the current across the heart by way of the arms that kills you.
              • Never wear jewelry of any kind on your hands or wrists - gold and silver are highly conductive, and it's a good excuse to use when your wife catches you without your wedding ring on.
              • Always unplug an amp before going in to solder something - don't depend on the power switches.
              • Don't chew on a length of solder while contemplating your next move - ingesting lead kills brain cells....
              • ...what were we talking about? Oh, yes, now I remember....
              • Use a variac to bring up an amp after mods or on new builds - carefully monitor the current and shut it down if it rises quickly at low voltages. Alternately, make a fixture with a light bulb in a socket that is in series with one side of the AC line - if the amp has a major short, the light bulb will light up instead of blowing the fuse or vaporizing your new power transformer.
              • A $150 transformer will blow every time to protect a 50 cent fuse - be sure to use a fuse of the correct rating and type! This usually means slo-blo in the mains, and a fast blow in the HT line, rated for no more than 150% of the max current draw at full power.
              • Wear safety glasses while working on amps. If you've never seen what happens when you wire in a large (or even small) electrolytic capacitor backwards, or exceed it's working voltage, you're in for the scare of your life! Hint: smoke, tar, and chicken feathers, following rapid explosive decompression and a launched projectile the size of a largish shell casing. If you get hit in the face with this exploding mixture, not only will you look like Daffy Duck with his beak blown off, you may sustain serious eye damage. I once had a very large electrolyic go off in my face, leaving me with a cut on my nose from the can, a melted contact lens from a piece of hot metal, and the aforementioned Daffy Duck look. I was able to laugh at myself only after realizing I wasn't permanently blinded in one eye.
              • Never work on amps around small children - you will be embarrassed when they pick up the language you use when you touch live wires.
              • When clipping wires or component leads with diagonal pliers, point them away from you - the cut leads fly off with incredible velocities, and can easily damage your eyes - again, use safety glasses!
              • Electrolytic (and other type) filter capacitors can hold lethal charges - be sure to discharge them before working on an amplifier. This can be done by shorting the "+" side to the "-" side, or the "+" side to the chassis (unless the cap is in a negative voltage supply, like the bias supply, where you must short the "-" side to the chassis), using a wire or a screwdriver. This will make a big spark and a loud noise, which is sure to impress any onlookers. If you'd rather do it more discreetly, make a jumper cable consisting of alligator clips on the ends, with a resistor in series in the middle of the jumper. Use a value of somewhere between 10K and 100K, with a power rating of 5W or so (a high power rating is not really necessary for dissipation reasons, but mainly because the higher power resistors are physically more robust and won't tend to break). Be sure to adequately insulate the resistor with heat-shrink tubing so the wires aren't exposed, or you'll get shocked while trying to discharge the capacitors. The larger the value of the resistor, the longer it will take to discharge the caps, and the less of a spark you will see. If you use a large value resistor, be sure to leave it in place long enough for it to drain all the charge out of the capacitor (if in doubt, measure the voltage across the capacitor to make sure it is close to zero). Note that many amplifiers will incorporate "bleeder" resistors, which will drain the capacitor charge automatically in a few minutes after the amp is turned off. Don't depend on this resistor to do it's job!
              • Be sure to turn the power off to the amplifier before discharging the electrolytic filter capacitors, or you will get an unpleasant surprise.
              • Be sure to remove any capacitor-discharging jumper wires before re-powering up the amp, or you will get another unpleasant surprise.
              • Get your wife/friend/co-worker/etc. to take a CPR course. Don't argue if they ask you to pay for it.
              • Tubes get hot, it's their job, especially power tubes. Don't touch them.
              • Don't install tubes with the power on - if the glass breaks, you can come in contact with high voltages. A shock after a nasty cut just adds insult to injury.
              • Buss wire looks exactly like solder, but doesn't melt worth a damn.
              • Never solder in your underwear (don't ask!). Seriously, short pants and soldering don't mix very well. Wear appropriate clothing.
              • Learn from other's mistakes - it's cheaper and far less painful.
              Copyright © 2004, Randall Aiken. May not be reproduced in any form without written approval from Aiken Amplification. Revised 08/14/04
              Bruce
              Mission Amps
              Denver, CO. 80022
              www.missionamps.com
              303-955-2412
                Thanks Bruce, good tips. I do actually follow all those for sure...
                So, not to belabor the point, as I gladly accept that I could use more training, but... I decided to do a little experiment. I'm a molecular biology grad student so have access to lots of DC power sources for running gels. To determine whether nitrile gloves would provide adequate resistance / protection against high voltage, I did the following:
                1. filled a gel box with eletrtrolytic saline
                2. attached the negative terminal as per usual.
                3. cut out a small section of nitrile from a glove and placed that on the positive terminal.
                4. attached the positive electrode to the nitrile-covered positive terminal.
                5. slowly increased the voltage to 350V. let the power supply run for ~10 minutes.
                6. reversed the polarity of this configuration and repeated it.
                The results? At no time did I generate any current through the saline, as measured both by the power sources amp meter and by a lack of hydrogen bubble production at the cathode and oxygen production at the anode.
                Does this mean I believe nitrile gloves provide completely adequate protection, or that I can be cavalier when working on the amp as long as I'm wearing gloves? Totally not. Does it provide an extra means of protection? yes.
                  hey, in the past i used heavy duty latex gloves to work on household line circuits without de-energizing the circuit.
                  just because i got away with it doesn't make it a good idea!
                    I used nitrile gloves in my time as an auto mechanic and continue to use them for various things. I wouldn't ever trust them to protect me from high voltage because they break unpredictably and without any warning!
                    jamie
                      What a cool experiment!
                      Huh!
                      A lack of Hydrogen bubbles.
                      I am going back to school.
                        jamie
                        that's I think the biggest fault of those gloves, their propsensity to tear. I definitely don't trust them to provide me complete protection. Kind of like the blowout preventor in the deep water horizon oil rig... oh wait, terrible example
