Hello,
I have a problem with the service of a Carvin X-50B.
The second grids of the power output tubes (EL34) are turning red to orange when the amp is going into overload, never mind from the clean or lead channel. This leads to early failure of the tubes.
The real problem is, that everything seems to be OK.
The output transformer is OK, as seen from the graphic, representing the Raa.
The Anode idle current is correct as the producer defines it (50mA), and a little less, for more distortion (cool biased).
The power supply voltages seem to be in normal condition - Anode (Va) 448v, G2 440v.
The G2 resistors are OK, 350R each G2 and common 350R from the Va.
The Anode currents at full power are 144mA each, average measurement, and the common G2 current is 115mA (2x57.5).
In this situation the G2 heats to red and more, which according to essential knowlege for the right work of the tubes is unacceptable.
The input signals to G1 are normal.
Tried even some weird assumption, if the G3 (suppressor) is floating, due to some connection loose, and the dynatronic effect to take place, but nothing of the kind.
So, my questions are directed to the respected qualified and experienced persons in the forum.
-Is this situation normal for this amplifier (which is very doubtful for Carvin)?
-Does anyone has experience with such problem, not only with this kind of manufacturer?
-What am I not confirming, that can be the reason for this problem?
Thank you in advance!
Tony Manov, M.Sc. AES member
