Hello - I just completed blackfacing a Silverface Fender Twin Reverb 100W Master w/JBLs. It sounds tonally very good, but has bad buzz+hum on both channels only with guitar plugged in.
What's been done:
* Removed Master Volume from circuit, including its "extra" parts and push/pull. Circuit is now wired exactly like AB763
* Replaced all filter caps + all electrolytics, changed power resistors between caps to 1k / 4.7k. Replaced coupling caps.
* Removed Hum Balance Pot and wired DC 40v circuit to heater wires
* Bias circuit wired as AB763
* Tried playing with lead dress, no luck.
* Replaced all power tube grid 470 ohm resistors
* Replaced all 100k carbon resistors with carbon comp
* I've swapped tubes around, 12AT7s are new but 12AX7s are not.
Symptoms:
* No guitar plugged in = no hum/buzz other than normal noise floor as I increase volume on either channel
* Guitar plugged in = both channels buzz increase with volume. It sounds like I've stuck the guitar pickup close to a transformer... doesn't matter what position guitar is in. If I turn down volume on guitar, all buzz goes away. Doesn't matter what pickups and I've tried two cables and two different guitars.
* Same buzz occurs with just a cable plugged in and no guitar.
* Vibrato is off, knobs don't affect anything.
* Reverb is working
The only thing I haven't tried yet is there are two tubes that have their Cathode Bypass Caps grounded to Reverb jacks - I know on blackface twins those are mounted on the board and grounded commonly there... could that possibly an issue? There really isn't much room to move those on board so I've been avoiding it.
Any other suggestions? I want to be able to record this thing! Thanks
-kdawg
What's been done:
Symptoms:
* Reverb is working
-kdawg
