73 Super Reverb
  • 73 Super Reverb
    73 Super Reverb....finally got it working....thanks Bill52 and others .........( someone
    had the neutral and hot wires reversed at the AC receptacle ) I am
    innocent....of course !
    Normal channel is great, but channel 2 has low volume, ( like it is on 1 or less ) even
    on 10. All tubes test good. Channel 2 Treble and Bass knobs are not working either.
    Reverb is working.
    Doc
    May I suggest that you measure Ch 2 preamp tubes at pin 1 & 3 / Pin 6 & 8.
    Post the results.
    Go from there.
      V4 236 2 63 2
      v5 372 0 366 0
      v6 240 92 214 92
        Vibrato Channel tube # V2 is the input tube for that channel.
        It seems to be missing.
        V5 is not doing anything.
        V4 & V6 look good.
          V2 221 2 199 2
          Thanks for the aa763 schematic.
          Doc
            V2 static voltages look good.
            You still must figure out why V5 is not conducting.
              'You still must figure out why V5 is not conducting.'
              V5 is the trem oscillator, if the footswitch isn't in and on then it won't be doing much; don't really need to worry about it at the moment?
              'V4 236 2 63 2'
              Pin 6 looks too low but the cathode voltage is holding up - could you confirm those?
              'v6 240 92 214 92 '
              Probably not relevent to the present issue, but it might be worth checking the plate resistors.
              'V2 221 2 199 2'
              OK but again the plate resistor values look like they may have drifted.
              Once the root cause has been identified, consider a campaign change out of all plate resistors.
              Pete.
                confirm......V4 pin 6 65v
                I'll check the PL resistors now
                  I shorted the vibrato pedal RCA jack and now I have pin 3 at 3v and pin 8 at 6v and Pin 1 at 480 and pin 6 at 405
                    Doc
                    Run a continuity test on the treble & bass controls.
                    Short of that, you can bypass the tone circuit with a temporary jumper wire.
                    If the amp livens up, you have localized the problem to the tone circuit.
                      Bass and treble controls .... good continuity.
                      How do I bypass the tone circuit........where does each end of the jumper wire connect ?
                        I would tack a capacitor (around 0.01uf) between the hot end of the volume control and the plate of the 1st stage, eg the plate side of the 250pF treble cap, and lift one of the 6k8 mid resistor legs (that goes to the chassis), whichever leg is easier. Pete.
