Hi,
I have a problem with my TSL100: while playing on the clean channel, the sound wen whisper-soft after just a minute or two with the faint smell of something burning. I turned the amp off quickly and after a few hours opened the rear grid to have a look.....nothing looked burnt, so i turned it on again.
On standby, the amp seemed fine. After 10 minutes of standby, I tried to play it again on the clean channel, and within a minute the left pair of tubes started glowing really hot, the plates became orange-red like a lightbulb! The right pair of tubes looked OK.
Shut down the amp again, once it was cooled I turned it on and checked the bias: the Left bias was 92mV and the Right was 60mV. (please note, Left valves were problem-hot, but Left pin bias was almost as per Marshall-spec-90mV, whereas Right bias seemed off).
So I did the only thing I could,which was adjust the bias, got both sides to read 90, and tsted the amp, it sounded fine even after 5 minutes of playing, the tubs seem to run normal and sound is good.
But I really don't know if just this one-side-bias discrepancy is the actual source of the problem, (and so I seem to have fixed it) or could it be something else I should be looking for......I'm afraid to run the amp and ruin it.
Question1: Could any of you experienced chaps care to comment please? I'd be very grateful for help,cos I live in South-east Asia where specialized tech help is extremely difficult
Question2: A related question: I understand that the bias is a -ve voltage, so in effect a 60mV reading instead of 90mV means it is running the valves extremely hot, yes? However on many internet sites there are techhies saying they'll set the bias at 80 instead of 90, cos this makes the amp run cold.......could this be right, if so how in god's name???
Thanks for your time,
Raggy
My website explains what I do with my amp!
Raggy
