This amp was working but crackling and distorting on both channels. It sounded like a bad solder joint. Poking around, I got a reaction/noise at the ribbon cable from the preamp board to the reverb board. Examining the reverb board, I found both loose solder joints at both regulator 1 and regulator 2. I reflowed/those joints and checked the remaining joints on the board. All looked good and I reassembled to try it out.
The amp played fine for about five minutes with no more crackling/distortion on either channel. Then there was a very harsh noise for about 5 seconds and all sound stopped.
Now, when power is turned on, there is a thump in the speakers, but no guitar sound through the amp. The channel switching, chorus on/off leds no longer light. I would appreciate it if someone could direct me where/how to start looking for the problem. I have precious little experience working on solid state amps.
The schematic is posted below. Any help will be most welcome.
stereochorusrev_2x80w_8280[1].pdfThanks
