Hi,
I'm facing a problem with my Fender Princeton Reverb. It makes cracks starting at 4 on volume knob.
I've already changed speaker (for a weber), tubes, and electrolytic capacitors. They all had to be changed, i think, but the problem still remains.
Following testings, i found the cause of this issue. It comes from the reverb. When i disconnect the reverb tank, the amp works fine, no crackling. So i suppose there is a problem with this part of the circuit.
I've check the reverb tank : all seems to be fine, no broken wire. Also checked solder joints near the reverb jacks, again i've found nothing suspicious.
Would it be because of the reverb driver?
thanks for any kind of help!
regards,
Ed.
regards,
Ed.
