Good Day All,
I'm going thru an Ampeg SVT 4 Pro head that came in with very low output (per the owner), and I noticed a couple burnt resisters. Wasn't till I got the poard all out that I found that all of the .47/5 w, 47 ohm & 1.5k resistors on the A Hi side were shot. To get at these I had to unsolder all the devices on that heatsink and pull the whole thing out (sink + devices). I had to do that anyway, so... All five of the mosfets (IRFP240) on that side show continuity between sourrce, drain and gate when I use my tester set to diode/continuity. Of course the B side on that same heat sink show some resistance but no continuity.
Also seems that the A Lo side is bad also, but the bias resistors and the .47's test ok.
I guess my question is, if I'm getting continuity on both the D/S & G/S & D/G on a mosfet, then it's toast? I just want to make sure as Mouser has the IRF240's but not the IRFP9240's. The only place I can find those is from Loud Tech, everyone else (Mouser, Digikey, etc) are looking at 26-30 weeks backorder, but Loud also wants $11+ / device, making it $58 bucks just for the one side.
I'm still a novice with solid state amps, and this one seems kind of complicated.
I know when I do get the devices back in, I'll need to set the bias. Anything else I should test or look for? I also have replaced R118 and Q102 in the 'A' driver section as they were bad also. I'm kind of suprised that with all the baked devices and resistors that the fuses didn't blow.
any advice would be welcome.
Matt
Matt
