Digital effects board
  • Digital effects board
    I am hoping some of you guys that still have warranty status with Loud Technologies might be able to help. I was digging through some old amp parts and found an old Crate PA6FX. I noticed the digital effects board still in the cab mounted in an a small metal box. I pulled it out to incorporate it into one of my amp builds. It has the familiar one knob for multi effects selections, an "In and Out" and needs only a 5 volt supply. It actually has an on board 5 volt regulator. I wired it up in place of the old Fender spring reverb and with very few mods it sounds beautiful. I hard wired the pot to full reverb and used the existing reverb level on the amp for the return. Please don't confuse this with the digital reverb unit CE distribution offers. I've tried to do the same thing with them and had poor results. I've called the old SLM number in St. Louis and can't get any info on ordering several of these. I used to be an authorized warranty repair center until they sold out to Loud Tech. Finally my question is, would anybody happen to know where they out source these boards from? The board number is 06A811-01. All I can get out of the parts line is they most likely wont have that part since Crate is history.
    Just a shot in the dark....
    Since the board has a 7805 on it, you'd need around 12vdc (or more up to 32v) input unless you remove the 7805 reg and wire 5v right to the output pad of that v reg.
      I've been using 12 volt filament supplies so the power source is not a problem. I just wished I could find who manufactures these particular boards. I'm sure it's some company overseas. It's so easy to interface into a tube pre amp. Oh Well....
