I posted on here a little while ago about trying to improve the sound of my Peavey Valveking head, basically to make it a little less muddy. Since then I have made some minor changes to it. I changed C149 from 1 nF to 220 pF, put in new preamp tubes (2 Electro-Harmonix 12AX7s for the preamp and a Tung-Sol 12AX7 for the PI), and added a bias pot (swapping the 39k bias resistor R205 for a 15k resistor in series with a 50k pot). It's now biased a little hotter and I feel like the sound has definitely improved.
The issue I'm having now seems like a microphonic tube, but I'm not sure. After I had adjusted the bias to about 35mA per tube, I started getting a high-pitched squeal on both channels, even with no guitar plugged in, starting at about 5 on the lead volume and 8 or 9 on the clean volume.
I had 2 spare 12AX7s, used but definitely still working normally, and went about swapping tubes trying to isolate the problem. With both these spares in place of V1 and V2, I only got this squeal when the guitar was plugged in with its volume turned all the way down, on the lead channel, with gain at 10 and volume at 7, or about 5 when the gain boost was engaged.
Then I thought, what the heck, and put the original tubes back in. Now I can't reproduce the squeal with the guitar unplugged, but it still comes back as before, with fairly high gain and volume settings. The tapping-on-the-tubes-with-a-guitar-pick test didn't produce any unusual sounds either, at least with the guitar unplugged.
I'm wondering if this indeed sounds like a microphonic tube problem, or if it might have been caused by something else. I had initially set the bias to a cold 15mA per tube just to see how it sounded, and played with that setting for about an hour before running it up to about 35mA per tube. So my other thought was that this could be an effect of the tubes settling into this new operating condition.
I'll post a schematic in case it helps; any thoughts on this issue would be very much appreciated as I'd rather not have to take this amp into a tech if it's just a minor fix.
http://music-electronics-forum.com/a...ng_100_212.pdf
