Peavey TB Raxx - Transformer Secondary winding
  • Peavey TB Raxx - Transformer Secondary winding
    Hi guys,
    I need to replace a dead transformer in a Peavy TB raxx.
    Does anyone know what the secondary windings are - they are not listed on the schematic.
    The peavey Part no. is 70529303
    Cheers!
    Just see if Peavey still has the part available. I don't think you'll find an off the shelf replacement since they were low profile. Just FYI, the "tg raxx" used the same pwr supply.
      Hey, did you find what are the secondary windings?
      I'm looking for exact same transformer specs
        Not too sure if it will help but here is the schematic.
        Peavey TB Raxx.pdf
        It looks like it has a high voltage winding and a low voltage winding.
          Oh thank you! That was useful!
          At least now one of the windings is clearly about 24V!
          I'm looking for the Rockmaster transformer specs. That's the same transformer 70529303
          https://music-electronics-forum.com/...ad.php?t=47870
            The secondary specs for the 70529303 are:
            Sec 1 322 vac @ .041 amps
            Sec 2 41.9 vac CT @ .403
            That's the answer from Peavey
              Peavey comes through Golden once again.
