Enzo, or neone that can help me please.
I have a hartke HA3500 from Dec 1993 I just recieved.
The fuse is blown & the B+ cap is short (C401)
as I didn't see/measure any other shorts in the power supply, I initially replaced cap w/ 105 degree cap of same value/voltage and the fuse.
worked fine for about 20min (master volume on 3, preamps volumes at about 4 , with an 8 ohm load).
Then it vented the cap (I turned off before it shorted).
In both of these times I played for a few mins then stopped and was about to resume maybe even hit a note when pow there goes the cap again..
I tested the bridge rectifier D401 didn't appear shorted (fwd, or rev biased) but the measurements were slightly different from the neg and pos portion of fwd biasing.
.48v and .51v
I have a new toroidial xformer , so I made the swap, and replaced c401 again.. I checked the bias between tp301 and 302 and was 2.8mv with an 8ohm load. (I left it alone). On fri night, sounded good played a couple tunes and was done, but I just powered up today (Mon), and same thing after about 20min if that. The cap vented yet again.
This Ha3500 does not have 2sd2155's, or 2sb1429's but rather is using KTC5200's, and KTA1493's which appear to be a similar/compatible? part.
I am at a loss- the rectifier didn't seem bad, the xformer is/was new, what else could be taxing c401 to make it vent?
could it be a faulty bridge, or are the power transistors the wrong ones entirely, or is there something else I am overlooking?
.48v and .51v
