Hello folks,
I am servicing a Fender 75 combo amp that has an unusual issue. Find Fender Twin II schemo attached. The power supply seciton in question is the same as the Fender 75 save not being fused. I hope the attachment makes it, I don't see it in the initial mail.
The problem is if the filters are discharged (even with the stby sw in stby) , these 2 fuses pop when the power switch is turned on.
Seems the initial surge to the caps draws more that 1amp, as 1amp fuses will similarly blow.
If the attachment doesn't get there, the B+ from the bridge goes to the upper cap....that cap is in series with another of the same value. There are 220K divider resistors across both caps. The lower one goes to ground. The center tap of the bridge winding goes to the point where the 2 caps meet. (perhaps someone can explain that arrangement, too). BTW, with the stby switch in stby, the B+ stops here & goes no where else.
I'm thinking of adding a surge resistor in series with the B+ line to the caps (or perhaps inseries with the fuses).
Any ideas? The filters have been replaced & the 220K divider resistor are what's in there.
Thanx, glen
Thanx, glen
