Crate BV50-H loud hum on clean channel
  • Crate BV50-H loud hum on clean channel
    OK..so I got the Crate together after changing filter caps ,and some tone stack components. Tubes in ,power on, no input , I'm getting a very loud hum. So...when it cools I'll take a look at my work. Note: I had to alter the filter cap placement because they were taller , so they are laying over as opposed to standing. I changed a couple of resistor values ,and wattage in the tone circuit ,as well as cap value.
    I switched to the dirty channel ,and it is quiet as a church mouse. Plate voltage is 470 , Tube bias reading is 22.2 ma , tubes are JJ KT66.
    I haven't tried much else yet . I will swap preamp tubes later after work.
    Thanks
    Crate BV50-H updated ,shematics
    After checking solder joints ,and a general lookover ,I powered up again , checked some voltages with the quiet channel on (channel 2), no input , Voltages seem a little high ,more so on V1 than V2. When I switched to channel 1 the hum still there, I poked around nothing made any sound change. When I was reading voltages with this one on ,and touched the socket pins it was really making some noises ,and seems to make the hum louder . I did also check the filament voltage ,and it is low at about 3.2 from ground to TP. Unless that is measured across which actually would be 6.4 . Maybe the resistors I changed could cause this ?
    V1-6 expected 180vdc , actual 205vdc
    V1-1 expected 190vdc , actual 207vdc
    V2-6 expected 140vdc , actual 165vdc
    V2-1 expected 170vdc , actual 185vdc
    Ok..apparently it didn'.t like my component changes, so they have been corrected (mostly), and the hums is gone. Live ,and learn
    Other voltages seem pretty close.
