I have a Crate Palomino V16 on my bench that was dropped out of the back of a truck. The owner said after that, the amp powered up but the sound is now extremely thin. All of the tubes check out OK (I have a B & K 747 tube tester) and the voltages are all in line with the schematic that I have. I pointed out that the reverb tank was removed and asked if this happened before or after the fall and he was unaware that the tank was missing. I am going to plug in a reverb tank that I have laying around to see if it makes any difference. The next step will be pulling the PCB to check for any damage. Has anyone run into this issue with the Crate Palominos? Anything I should be looking at? I am new to this forum and am a member of several others but they do not deal with Crate amps.
Thanks,
Dan
Thanks,
Dan
