My Fender Delux is suddenly distorted on the clean channel (yellow light) and clean on the Distortion 1 channel (yellow and red on); the distortion 2 (two red lights) seems normal. Any solutions greatly appreciated.
Fender Hot Rod Delux
So the indicator LED's are functioning properly, correct?
If they are, then that indicates the relays.
What I have found on these HR amps is the masking around the PCB holes for the relays is really small.
They did not leave very much room for the solder to attach to the copper pad.
You could try resoldering the relays.
(FYI: These amps are a real PITA to get the main circuit board out. If you do not feel comfortable working on it, take it to a repair shop)Last edited by Jazz P Bass; 04-30-2011, 04:48 PM.
