This is the 1x12 100 watt marshall model 2150, celestion powercell speaker....it looks to be pretty much a model 1959 w/6550s and a post-PI master volume. There is a mains fuse on the back panel, and a fuse PCB w/9 additional fuses for filaments x 4, CT, HT x 2, bias and mains. All the fuses meter continuous.
I measure ~3.2VAC on all heater pins of all tube sockets. But none of the tubes are lighting up or feeling warm. Power tube plates and screens are measuring ~480VDC, and there's about -53VDC on pin 5 of each power tube...all normal.
These are the high voltages measured on the preamp tubes and phase inverter....
V3(PI) 461VDC pins 1 + 6
V2 pin1 456 pin6 451
V1 pin1 451 pin6 447
The 10k dropping resistors are all w/in spec, as are the plate resistors on V1-3
I am missing something here....maybe one or more of the cap cans are bad? thanks for your help!
2150 Power amp schematic: http://drtube.com/schematics/marshall/78614-3.gif
2150 Preamp schematic: http://drtube.com/schematics/marshall/78614-2.gif
