Got an SVT CL here. It has a new, matched set of Svetlana 6550Cs in it. It biases up correctly and is stable at idle. You can run it up pretty loud, but if you drive it into clipping the fault detection circuits operate almost immediately - with twinkly flashes from inside the valves. (For those of you concerned about my neighbours, I'm running it into a dummy load).
I've tested the O/P transformer ratio with an AC signal and checked the isolation to 1500V.
I tried biasing completely cold and the fault still occurs. The suppliers have suggested that I return the 6550Cs to them for testing. Before I do this, is there anything else I should check?
