Ok..I would like to know if I have this bias pot wired correctly. I was told to solder the wiper to one tab , wire that to a 5K resistor, and then to one hole where the bias resistor used to be , then wire the other tab to the other hole. Is this correct ? My problem with that was that I wasn't getting enough bias current so I had to increase the resistor to 20K.
Thanks !
Thanks !
