crate v100h problem
  • crate v100h problem
    My v100h is not working on the pre amp stage on both channels. However it work using the return path. Could it be a issue on the preamp valves?
    Also i´m trying understand this amp scheatics, but is a no sense on the channels part.
    Try running a patch cord from the pre send jack to the pre return jack.
    You may have a bad normally closed contact on the return jack.
