I've replaced almost everything on the output board of this amp. Shematic here: http://s1122.photobucket.com/albums/...ter/Yamaha/GFS NYII?action=vGFS NYIIiew¤t=Yamaha_G100_series_I2.jpg&newest=1
At point test point "5" I have about 30vdc, and after the output coupling cap I also have about 30vdc. The other speaker wire has no DC present, I did not replace this cap, is this a sign that it is leaky? It is a 2200uF 100v cap. When I got the amp to fix it almost all the transistors were blown due to a short from the output transistors mounting screw touching the copper tracing. When I fire it up with a bulb limiter it is a perfect dim glow with 100w bulb. All other voltages check out exept on the Output.
