Ive got a PR that has a low freq. hum. sounds like its around 160-200hz
Ive done a few things :
checked volts and bias
swapped all tubes
the hum is not affected when i short V1 pin 2 ... V2 pins 2/7 .V3 pin 2
it reduces the hum a little when i short V1 pin 7
it kills the hum when i short V3 pin 7 --amp gets quiet
having the reverb tank plugged in has no affect
turning the rev pot changes the hum a bit, but doesnt really kill it or drastically reduce it..
its there with the Volume on 0 , turning it up the amp and hum gets louder .
i swapped 3 caps right before that stage (v3 pin7 ) = .022 , .003 , 10pf .
i tried moving the wires around
is this stage supposed to have a shielded cable? all the wires are new cloth style
all the caps were replaced in 2003
i found the 2 100 ohm heater resistors near the light were burnt, i replaced those .
any ideas ?
swapped all tubes
any ideas ?
