Hi,
I just picked up a 1959HW. The valves are all 7 years old and the previous owner is a guitarist in an internationally known hard rock band, so the amp has been played hard and regular. Accordingly I want to replace the power valves.
The only method of biasing I'm comfortable with is the cathode current method but this amp has pins 8 and 1 of every power valve wired straight to earth with no 1ohm resistor in the way. I'm not really keen to put resistors in and then remove them straight afterwards, so I'm wondering what - if any - effect they would have on the tone of the amp if I put them in and left them in?
Alternatively is there a trick for performing this method of biasing without the 1ohm resistor, or perhaps another simple, safe biasing method that can be done with just a multimeter?
