I found this strange. I got this amp up and running and was using clips on the screw terminals to listen to it with a heavy duty 4 ohm speaker (black widow) that I use to test most of the amps in my shop. And it sounded great. Then, since I was hoping to use this as a guitar amp I went to installed a 1/4" speaker jack. So I disconnected the octal socket that has all the secondary OT connections and soldered up the jack with the 8 ohm tap and then used the 'C' black lead for the other end of the winding.
After some time of playing and it sounding really good I accidentally, (zap!) found that there was voltage on the screw lugs where the 16 ohm and 4 ohm leads were still attached and come to find out that my 8 ohm winding also has about 400v on it.
My question is how did my speaker survive that much DC? It still works and sounds fine, I would think that would have blow it.
Unless I'm missing something, my guess is that the OT insulation between the primary and secondary broke down. I finally disconnected all of the secondary and found that there was 74 ohms betw the CT red lead and all the secondary winding taps and 400vdc, except for the winding that is used for the NFB.
Here's a link to a thread that has a good picture of the schematic in case my attachment isn't easy to read.
http://music-electronics-forum.com/t10715/
