Hi guys, I'm new here
I run a small electronics repair shop and recently started getting in to guitar amps and heads. I am really no expert and am kinda learning as I go. I have successfully repaired a couple Trace Elliot heads before, but this one is something new- it's an AH300, a real beast actually the fan blows hard enough to keep the sweat off your face in a hot club i guess hehe, anyway, It fires up OK, the preamp stage seems to be working correctly, but the output is constantly distorted and fades in and out. I tested each giant cap and ESR seems OK, capacitance shows ~5500, but voltage wise, after the amp is turned off one cap holds 70v, while the other is back at 0v. I poked around with a stick and nothing seems to affect the output, and there is no voltage at the outputs either. would that cap be bad or should I look at the output transistors; or am I totally lost? Thanks for any input!
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
