Hi,
What would be the most likely cause. There is a BF Bandmaster, that suddenly started to lose power. It turned out that both power tubes all of a sudden started glowing. It was running with Tung Sol 5881s. The plate voltage is almost 10% above the specified limit of those tubes but they were moderately biased and have been running great and flawlessly for half a year or so with decent use. Could it be that they finally gave in due to the high plate voltage? But is it likely that both started glowing at the same time? Wouldn't just one give in or does the other one always die as soon as the first one dies? I heard that the Tung Sols can take it if not biased too hot but I guess that 400V limit isn't there for nothing either ...
What are other likely causes? Defect bias circuit?
thanks
BF
thanks
BF
