Hi,
I would be very grateful for any help in diagnosing a noise problem with an Engl Screamer valve amp.
The amp exhibits additional noise, but only when a note is played. No guitar signal and no noise. In all other regards the amp is behaving fine, I haven’t noticed any deterioration in volume or tone etc or background noise. The noise is like that of rustling paper, a bit crackly or a bit like a flabby speaker.
I’ve done the obvious things and gone through all the valves with no change or improvement. This included the pre-amp and power amp valves. I’ve tried different guitars and the behaviour is the same. The noise is certainly more prominent in the lower notes and almost goes on the higher notes, and also increases in volume with the general amp volume if the master volume is increased.
I’ve also noticed that the noise is present on the effects loop send signal, and interesting, if I only input to the amp via the return the noise is also present on the audible output.
As a bit of history, this amp has recently had the PSU capacitors replaced. Two of the three caps showed signs of leaking and this work was initiated by noticing a general hum noise from the amp that was constant and independent of the master volume. (A different type of noise altogether to that now occurring).
Could there be another PSU related problem? I really would be grateful for any pointers or suggestions from the more experienced.
My thanks in advance…………..
