I am working on a 1972 Super Reverb that has previously been "blackfaced". I solved some issues with the VIBRATO channel and it sounds perfect and the reverb and vibrato now both work, but the NORMAL channel makes no sound.
I have double-checked component values and wiring and everything "seems" to be correct. I have swapped tubes in and out with no luck. If I touch the meter probe to the middle lug of the volume pot I get a strong hum like I do with the other channel but beyond that there is no sound, not even static.
Also, I am seeing almost 400 volts on pin 1 V1.
Any suggestions as to how to proceed with troubleshooting would be much appreciated.
