I am new at posting here but read entries from time to time to try and learn something new. I have a B-52 AT212 combo which I purchased in 2008. Unlike most people that post things about these amps, I have never had any problems with the amp...until recently. I typically power up the amp for 6 to 8 hours per week. The other day I powered up and heard nothing when plugging in. Usually I'll hear some static, maybe a 60 cycle hum etc. when plugging in but on this day nothing. I first thought I left it on stand-by but this was not the case. I checked each channel and it was the same on each. I then slowly turned up the master volume and each channel's volume and when the master was at 3 o'clock and each channel's volume was at about the same I could start to hear the guitar and static. It was very weak - could barely hear it. So I looked through the metal grate on the back and could see that all the 12AX7's were lit. One was much dimmer than the others but lit. The 6L6's were all lit as well. Two of the 12AX7's could not be seen because they each have a metal sleeve around them. I believe these are related to the phase inverter and effects loop tubes. The speakers were both wired properly. I never have taken the back off of the amp because I never had to and always thought it would void the warranty if I left traces of me being in there. If this turned out to be a tube replacement issue I would do that myself as I believe the odds of something major happening before the warranty expires are slim. Anyhow, has anyone had a similar problem on any amp? My father was an electrical engineer for 50 years before retiring (at 77) and I've learned a lot from him. Mostly solid state stuff. We never discussed tube amps before he passed away so I'm not that informed about them. I emailed B52 and have not yet heard back. I thought I'd ask here before I call to find out where their service centers are located. I do have a schematic if needed.
Thanks for any help!
Chris
Chris
