I just bought this amp today and don't want to break anything. I heard from someone that if I wanted to change the rectifier mode (this amp has 3 modes: Solid state rectifier, hybrid rectifier, and tube rectifier), I would have to re-bias the amp head. Is this true?
Changing rectifier modes in B52 AT100...
Incorrect. Everything should be already set correctly. When you change power tubes, then you'll have to set the bias again. I've worked on one of these and it had 2 separate bias pots inside for the different rectifier modes, but they should have been properly set at the factory. You should be good to go at this point.
